Clear Screen
I need to know how to clear the termianl window screen from within MPLAB. ex. printf("blahblahblah
") instead of
i need something to clear the screen, if there is nothing like this please tell me a method of doing this.
There is no direct command or special ASCII the IFI Terminal Window will recognize (or at least not the last time I tried the entire ASCII string set), but you can simply send a whole bunch of carriage returns, e.g.,
printf("/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r");
You could write your own terminal or use another free one that does have a character that will clear the screen
Get a good terminal emulator, like TeraTerm, and then Google “terminal escape sequence” for the character strings that can be sent to the terminal emulator to create pretty cool user interfaces.
-Kevin
system(“cls”);
or…
system(“clear”);
If you choose Adam 3A terminal emulation and then find a terminal program that supports it, you can have a complete way to control where text is put on the screen.
I dont think these work on the RC, because these are actually external function calls to the windows terminal, but I may be wrong.
