In demo mode CMU2 is able to track the brightest color in the room. However, when are not in the demo mode our robot is unable to give back data. Also tracking does not work in the GUI. Any suggestions?
Are you using labview, or the java app to try to track?
Demo mode requires alot of Light!! … i mean alot:P sucks tho… Also … if ur using the Java GUI… make sure that you do not have both 232 ports connected.
