I am about to throw this camera out the window i’m so confuzeled. What my problem is, is that i cant get the java camera thingy to work it says:
Looking for camera…
I had it working once and now it wont, Now when i start up the java app the red led turns off and it stops working. Has anyone else had this problem or has any insight on how i might fix it.
Make sure you have the TTL/RS-232 Converter card disconnected from the RC or else the GUI might not function correctly. I would say to check your version of java, but since you had it working before I guess you’re good to go (but I would still download the newest version anyway).
-The camera powers from the backup battery , it must be charged.
If TTL port is connected to the R/C the camera will not work witht he Java applet (for us)
-If you have your IFI loader running you wont be able to run your Java applet since your COM port is already being used.
-Sometimes you need to turn the camera off and then on to make it work
-make sure your PWM’s are gving out more than 5 VDC (we had that problem, then we just ran the camera off of a seperate 12V battery with limited current)
the jumper near the top right of the camera across form the serial cable needs to be on
-be sure you get a red and green LED lights
-if you haven’t already configure the serial port to the proper data bit rate.
-Just power the PWM at the bottom and use the serial to your computer.
I don’t want to renew this thread, but I don’t understand how I can get red and green LED lights on together. I tried unplugging everything and leave it alone for a few minutes (that worked once or twice), turning it on and off, toying with the whole thing, but nothing works. I know this question has been asked many, many times on this forum, but can someone make a general enlightenment to my aching head?
