I’d agree with Ari about those tolerances.
Another note about bearing hole press fits. You need to be incredibly accurate as Ari said but as long as your CNC is incredibly precise you can manipulate the CAD to make sure the bearing hole is the right size.
We did this with our CNC. If given a bearing hole size it can cut 10 instances of the hole with +/- .001 of each other but the holes were consistently .007 larger than they were supposed to be. We fixed this by under-sizing all our bearing holes for press fits by .007 and then we could cut 10 bearing press fits no problem.
Not sure if this is a problem that lots of people have, or if it’s just us but I figured it might help to know that.
