This is the code:
/* Copyright (c) 2018 FIRST. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package frc.robot;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMax.IdleMode;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import edu.wpi.cscore.UsbCamera;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the TimedRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the build.gradle file in the
* project.
* This function is run when the robot is first started up and should be used
* for any initialization code.
//***Controllers***
public Joystick driver_Controller;
public Joystick operator_Controller1;
public Joystick operator_Controller2;
//***Motors***
public CANSparkMax left_ChassisMaster;
public CANSparkMax left_ChassisSlave1;
public CANSparkMax left_ChassisSlave2;
public CANSparkMax right_ChassisMaster;
public CANSparkMax right_ChassisSlave1;
public CANSparkMax right_ChassisSlave2;
//***Motors ID***
public static final int left_MasterDeviceID = 6;
public static final int left_Follower1DeviceID = 9;
public static final int left_Follower2DeviceID = 11;
public static final int right_MasterDeviceID = 1;
public static final int right_Follower1DeviceID = 7;
public static final int right_FollowerDeviceID = 10;
//***Chassis***
private DifferentialDrive driveTrain;
//***Reversa***
protected boolean reverse = false;
//***Compressor***
public Compressor airCompressor;
//***Solenoids***
//Gearbox
public DoubleSolenoid gearbox;
//Toggle
boolean toggle1 = true;
boolean toggle2 = true;
@Override
public void robotInit() {
//***Joystics Port Assigned***
driver_Controller = new Joystick(0);
operator_Controller1 = new Joystick(1);
operator_Controller1 = new Joystick(2);
//***Motors Id Assigned***
left_ChassisMaster = new CANSparkMax(left_MasterDeviceID, MotorType.kBrushless);
left_ChassisSlave1 = new CANSparkMax(left_Follower1DeviceID, MotorType.kBrushless);
left_ChassisSlave2 = new CANSparkMax(left_Follower2DeviceID, MotorType.kBrushless);
right_ChassisMaster = new CANSparkMax(right_MasterDeviceID, MotorType.kBrushless);
right_ChassisSlave1 = new CANSparkMax(right_Follower1DeviceID, MotorType.kBrushless);
right_ChassisSlave2 = new CANSparkMax(right_FollowerDeviceID, MotorType.kBrushless);
//***Follower Mode Activated***
left_ChassisSlave1.follow(left_ChassisMaster);
left_ChassisSlave2.follow(left_ChassisMaster);
right_ChassisSlave1.follow(right_ChassisMaster);
right_ChassisSlave2.follow(right_ChassisMaster);
//***Amp Limit***
left_ChassisMaster.setSmartCurrentLimit(40);
left_ChassisSlave1.setSmartCurrentLimit(40);
left_ChassisSlave2.setSmartCurrentLimit(40);
right_ChassisMaster.setSmartCurrentLimit(40);
right_ChassisSlave1.setSmartCurrentLimit(40);
right_ChassisSlave2.setSmartCurrentLimit(40);
//***Ramp Value***
double ramp = 0.75;
//***Ramp Rate***
left_ChassisMaster.setOpenLoopRampRate(ramp);
right_ChassisMaster.setOpenLoopRampRate(ramp);
left_ChassisSlave1.setOpenLoopRampRate(ramp);
left_ChassisSlave2.setOpenLoopRampRate(ramp);
right_ChassisSlave1.setOpenLoopRampRate(ramp);
right_ChassisSlave2.setOpenLoopRampRate(ramp);
//***BrakeMode Selected***
left_ChassisMaster.setIdleMode(IdleMode.kBrake);
left_ChassisSlave1.setIdleMode(IdleMode.kBrake);
left_ChassisSlave2.setIdleMode(IdleMode.kBrake);
right_ChassisMaster.setIdleMode(IdleMode.kBrake);
right_ChassisSlave1.setIdleMode(IdleMode.kBrake);
right_ChassisSlave2.setIdleMode(IdleMode.kBrake);
//***Air Compressor Id Assigned***
airCompressor = new Compressor(0);
//***AirCompressor Security***
airCompressor.setClosedLoopControl(true);
//***AirCompressor Start***
airCompressor.start();
//***States Values Assigned***
airCompressor.enabled();
airCompressor.getPressureSwitchValue();
airCompressor.getCompressorCurrent();
new Thread(() -> {
UsbCamera c0 = CameraServer.getInstance().startAutomaticCapture();
c0.setFPS(30);
c0.setResolution(640, 480);
try {
Thread.sleep(20);
} catch (InterruptedException e) {
}).start();
public void kart1()
double x = (driver_Controller.getRawAxis(4));
double y = -(driver_Controller.getRawAxis(1));
double r = Math.sqrt(Math.pow(x, 2) + Math.pow(y, 2));
if (r > 1) {r = 1;}
double kLimiteX = 0.30;//75; //<<-- Sensibilidad de giro <<
double t = ((r - Math.abs(x)) * (1 - kLimiteX)) + (r * kLimiteX);
if (t > 1) { t = 1;}
reverse = false;
//***Foward & reverse***
if(y < 0)
double temp = -t;
t = -r;
r = temp;
reverse = true;
if (x < 0)
double temp = t;
t = r;
r = temp;
driveTrain.tankDrive(r,t);
public void kart2()
if (r > 1) {r = 1;}
reverse = false;
if(y < 0)
double temp = -t;
t = -r;
r = temp;
reverse = true;
if (x < 0)
double temp = t;
t = r;
r = temp;
driveTrain.tankDrive((r * 0.50) , (t * 0.50));
@Override
@Override
@Override
public void teleopInit() {
@Override
if(operator_Controller2.getRawButton(3)){
if(toggle2 == true){
toggle2 = false;
if(operator_Controller2.getRawButton(4)){
if(toggle2 == false){
toggle2 = true;
if(operator_Controller2.getRawButton(1)){
if(toggle1 == true){
toggle1 = false;
if(operator_Controller2.getRawButton(2)){
if(toggle1 == false){
toggle1 = true;
if(driver_Controller.getRawButtonPressed(1)){
gearbox.set(DoubleSolenoid.Value.kForward);
if(driver_Controller.getRawButtonPressed(2)){
gearbox.set(DoubleSolenoid.Value.kReverse);
if(toggle2)
if(toggle1){
kart1();
else
kart2();
else
left_ChassisMaster.stopMotor();
right_ChassisMaster.stopMotor();
@Override
public void testInit() {
@Override
public void testPeriodic() {
This is the error:
ERROR 1 Unable to retrieve SPARK MAX firmware version for CAN ID: 7. Please verify the deviceID field matches the configured CAN ID of the controller, and that the controller is connected to the CAN Bus. com.revrobotics.CANSparkMaxLowLevel.<init>(CANSparkMaxLowLevel.java:206)
ERROR 1 Unable to retrieve SPARK MAX firmware version for CAN ID: 10. Please verify the deviceID field matches the configured CAN ID of the controller, and that the controller is connected to the CAN Bus. com.revrobotics.CANSparkMaxLowLevel.<init>(CANSparkMaxLowLevel.java:206)
ERROR 1 Unhandled exception: java.lang.NullPointerException frc.robot.Robot.teleopPeriodic(Robot.java:243)
Warning at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:274): Robots should not quit, but yours did!
ERROR 1 The startCompetition() method (or methods called by it) should have handled the exception above. edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:276)
ERROR 1 Unable to retrieve SPARK MAX firmware version for CAN ID: 9. Please verify the deviceID field matches the configured CAN ID of the controller, and that the controller is connected to the CAN Bus. com.revrobotics.CANSparkMaxLowLevel.<init>(CANSparkMaxLowLevel.java:206)
ERROR 1 Unable to retrieve SPARK MAX firmware version for CAN ID: 11. Please verify the deviceID field matches the configured CAN ID of the controller, and that the controller is connected to the CAN Bus. com.revrobotics.CANSparkMaxLowLevel.<init>(CANSparkMaxLowLevel.java:206)
