Every time we try to deploy code to the roboRIO it fails. This is the error that is gives us:
Buildfile: C:\Users\Beehive Robotics\workspace\FRC2016\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\Beehive Robotics\workspace\FRC2016\build
[delete] Deleting directory C:\Users\Beehive Robotics\workspace\FRC2016\dist
compile:
[mkdir] Created dir: C:\Users\Beehive Robotics\workspace\FRC2016\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\Beehive Robotics/wpilib/java/current/lib/WPILib.jar:C:\Users\Beehive Robotics/wpilib/java/current/lib/NetworkTables.jar: to build
[javac] Compiling 5 source files to C:\Users\Beehive Robotics\workspace\FRC2016\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\Beehive Robotics\workspace\FRC2016\dist
[mkdir] Created dir: C:\Users\Beehive Robotics\workspace\FRC2016\build\jars
[echo] [athena-jar] Copying jars from C:\Users\Beehive Robotics/wpilib/java/current/lib/WPILib.jar:C:\Users\Beehive Robotics/wpilib/java/current/lib/NetworkTables.jar: to build/jars.
[copy] Copying 2 files to C:\Users\Beehive Robotics\workspace\FRC2016\build\jars
[jar] Building jar: C:\Users\Beehive Robotics\workspace\FRC2016\dist\FRCUserProgram.jar
get-target-ip:
[echo] Trying Target: roboRIO-4268-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: For the 2020 season software documentation has been moved to https://docs.wpilib.org. Documentation for KOP items can still be found here. | FRC KOP Documentation
[sshexec] Connecting to roboRIO-4268-FRC.local:22
[sshexec] cmd : test -d /usr/local/frc/JREBUILD FAILED
C:\Users\Beehive Robotics\wpilib\java\current\ant\build.xml:220: Remote command failed with exit status 1Total time: 10 seconds
Please help. Thank you for your help.
