Code Not Going to cRIO
I was doing a few tests today and I believe that the code that we are deploying off the laptop isn’t actually running on the cRIO. After testing code for the trigger (which did not work), I decided to run some other tests. I decided to comment out everything that was in the teleop method, and then deploy it. Afterwards, the robot still worked the same.
If anyone could help us out, it would be great. Thanks!
Does anyone have any suggestions?
Hey I would love to help you, but I need a little bit more information. Maybe if you posted your code or made a more thorough post about what it is your doing.
Okay, I will post that information tomorrow.
