When I deploy, everything builds and deploys totally fine as shown in the logs below, but when I open the driver station, it says that there is no robot code.
Executing task: gradlew deploy -PteamNumber=5000 --offline -Dorg.gradle.java.home=“C:\Users\Public\wpilib\2022\jdk” <
Starting a Gradle Daemon, 4 incompatible and 1 stopped Daemons could not be reused, use --status for details
Driver Station reported IP: 10.50.0.2
Task :discoverroborio
Discovering Target roborio
Using [email protected]:22 for target roborio
Task :deployprogramKillroborioroborio
-C-> sed -i -e ‘s/“exec /”/’ /usr/local/frc/bin/frcRunRobot.sh @ /home/lvuser
-[-1]
-C-> . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t 2> /dev/null @ /home/lvuser
-C-> sed -i -e ‘s/^StartupDLLs/;StartupDLLs/’ /etc/natinst/share/ni-rt.ini @ /home/lvuser
-[-1]
Task :deployrobotCommandfrcJavaroborio
-C-> echo '/usr/local/frc/JRE/bin/java -XX:+UseConcMarkSweepGC -XX:+AlwaysPreTouch -Djava.lang.invoke.stringConcat=BC_SB -Djava.library.path=/usr/local/frc/third-party/lib -jar “/home/lvuser/PneumaticsTestAgain.jar” ’ > /home/lvuser/robotCommand @ /home/lvuser
-[-1]
-C-> chmod +x /home/lvuser/robotCommand; chown lvuser /home/lvuser/robotCommand @ /home/lvuser
Task :deployfrcStaticFileDeployroborio
-C-> mkdir -p @ /home/lvuser/deploy
-[-1]
1 file(s) are up-to-date and were not deployed
Task :deployjrefrcJavaroborio
-C-> if [[ -f “/usr/local/frc/JRE/bin/java” ]]; then echo OK; else echo MISSING; fi @ /tmp
-[-1]-> OK
-C-> opkg list-installed | grep openjdk @ /tmp
-[0]-> frc2021-openjdk-11-jre - 11.0.9u11-1 - FRC OpenJDK Java Runtime Environment
Searching for JRE 11.0.9u11-1
Found JRE frc2021-openjdk-11-jre - 11.0.9u11-1 - FRC OpenJDK Java Runtime Environment
JRE Is Correct Version
Artifact skipped
Task :deployfrcJavaroborio
-C-> chmod +x “/home/lvuser/PneumaticsTestAgain.jar”; chown lvuser “/home/lvuser/PneumaticsTestAgain.jar” @ /home/lvuser
Task :deploynativeZipsfrcJavaroborio
25 file(s) are up-to-date and were not deployed
-C-> chmod -R 777 “/usr/local/frc/third-party/lib” || true; chown -R lvuser:ni “/usr/local/frc/third-party/lib” @ /usr/local/frc/third-party/li
-C-> ldconfig @ /usr/local/frc/third-party/lib
-[-1]
Task :deployprogramStartfrcJavaroborio
-C-> sync @ /home/lvuser
-[-1]
-C-> . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r 2> /dev/null @ /home/lvuser
BUILD SUCCESSFUL in 19s
13 actionable tasks: 11 executed, 2 up-to-date
Terminal will be reused by tasks, press any key to close it.
