Coding Help.
My team, for FTC , s using linear actuator sevos from actuaniz on our robot. However we are having the hardest time programming them. I dont know what kind of servo to configure them as and the proper code to write for it? If anyoone know about this please send edvice ASAP
Are you talking about these? If so, you should be able to program them exactly the same as you would a rotary servo. For an example of how to do that, look through the FTC-provided sample code and find the “ConceptScanServo” example. Hope that helps!
