Cog Depositing
Is your robot able to be in contact with the cog while it is being pulled up by the lift?
The general consensus is that it is fine, the Q and A will have been asked to clarify so an answer should be available most likely within a day or two.
There are a few threads with similiar questions/answers which can be found by using the “search” tool up the top of the page. Try searching for “Gear lifting” or “Peg lifting” etc. Just use key words/phrases.
Here is one of the threads with some good discussion:
https://www.chiefdelphi.com/forums/showthread.php?t=153116&highlight=lifting+gear
