That’s an area I know about. WOO HOO!
Look up Thermoelectric Device - you’ll have better luck.
Peliter effect is the heating and cooling.
It can be reversed, and controlled. It’s solid state (just a bunch of P-Type and N-type doped materials linked together) so it’s TOTALLY silent. It’s a solid state heat pump, which means that heat energy is pumped from one side to the other. The side that has energy removed gets cold, and the energy comes out on the hot side. Of course, because you power the unit, you end up with ALOT more energy on the hot side than you removed on the cold side. Not very efficient. But there is NO refridgerent. NO moving parts. NO fluids.
Also…
Seebeck effect covers the ability of a thermoelectric to produce electricity. If you heat one side, and cool the other, presto-change-o, you are producing a current.
I could write a few pages on how they work, but it’ll be quicker for you to look here: Lots of Thermoeletric links
Want to buy a few, cheap? Go to: BG Micro it’s a surplus place, but they normally have some cheap.
They have been around for years, and there have been VERY few advances for like 60-70 years. UNTIL the last few years - there have been some really good, big breakthroughs in the last few years.
And I leave you with a list of a FEW uses…
Little mini-desktop pop coolers
Travel coolers
Personal coolers at the Sharper Image (with the HUGE battery pack)
Heated/Cooled seats in vehicles (Amerigon is the company name.)
Lantern powered radios
Data collection on the Alaskan Pipeline (Relativly warm oil on one side, cold Alaska air on the other side = power)
Cooling on ICBM navigation systems (The Soviet scientists were way ahead on alot of this technology)
I have seen a prototype Semi truck with the alternator removed and a 1kW power generator hooked up to the hot air exhaust
And I think some NASA deep space probes used TEDs to produce power. Cold of space and warmth of nuclear material = power.
By the way, I have easy access to these things. So I ran the numbers last year. I can’t remember all the numbers, but you’ll use more battery power than it’s worth. Design your drive correctly in the first place (MANY white papers to help you out) and use fans if necessary. If you HAVE to, the can of cool will also work. But don’t do that unless you are REALLY having trouble. It’s expensive, it can damage motors, and it only fits the LEGAL definition of non-flamable. (It’s R-152, and I can make HUGE fireballs with it.)
Now, I am still playing with the dry ice* thermocapacitor idea…
*Dry ice can be VERY dangerous if you don’t know how to handle it. Don’t mess with it without help.
OK, my skills are all used up here, going back to lurking…
