Our robot will be in different starting positions depending on what autonomous code is being run. Does the LED have to be visible from the front of the robot or from the position of the other alliance’s robots, or both?
<R14> only says the front. If you have your LED facing forwards, you should be fine. If you still need clarification, there’s always Q&A.
