Is it just me, or do figures 3-22 and 3-23 conflict?
They both show a color order of Red-Yellow-Blue-Green, going clockwise, whether viewed from top or bottom. Shouldn’t one of those be reversed?
The direction counted as “clockwise” when viewed from the top is equivilent to the direction labeled “counterclockwise” as viewed from the bottom.
I don’t have the manual on-hand, but the color order should be reversed between the two diagrams.
Just checked the manual, and this does appear to be an inconsistency.
Sounds like another one for the Q&A…
There is a discrepancy between the two diagrams however the manual says (emphasis mine):
The CONTROL PANEL is divided into 8 equal size wedges. Wedges are red, green, blue, and yellow
(see Table 3-3 for CMYK values) and visible from above and below the CONTROL PANEL. Colors are arranged as shown in Figure 3-23 and line up top and bottom.
So if you view it from the top, it should go Red-Green-Blue-Yellow.
