Color Sensor Distance?
Hello I want to start testing the color sensor and when mounting it realized I had no idea how far from the control panel it should be.I have no experience with color sensors besides from my years in FLL. What is the ideal distance that the Kit of Parts color sensor should be mounted?
1cm-10cm per the website.
Thanks. I had problems accessing the website.
FIRST Capital Ri3D did a short segment or two on the REV color sensor. You could check that out too.
Experimentally, we had the best luck with 1 to 4 inches. Which roughly lines up with their spec online (as well as the sensor chip datasheet).
Awesome, will give it a try. Thanks.
