Command Based Java code deploys but it says no robot code?
I tried everything but it does not working. It deploys, code is not giving error but it says “No Robot Code”.
Here is the DriveSubsystem:
package frc.robot.subsystems;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
import com.ctre.phoenix.motorcontrol.can.WPI_TalonSRX;
import com.ctre.phoenix.motorcontrol.can.WPI_VictorSPX;
public class DriveSubsystem extends SubsystemBase {
    private WPI_VictorSPX frontleft = new WPI_VictorSPX(23);
    private WPI_TalonSRX frontright = new WPI_TalonSRX(24);
    private WPI_VictorSPX backleft = new WPI_VictorSPX(22);
    private WPI_VictorSPX backright = new WPI_VictorSPX(25);
    private  DifferentialDrive m_robotDrive_first = new DifferentialDrive(frontleft, frontright);
    private  DifferentialDrive m_robotDrive_second = new DifferentialDrive(backleft, backright);
    public DriveSubsystem() {
    @Override
    public void periodic() {
    public void setMotors(double rightXaxis, double leftYaxis) {
        m_robotDrive_first.arcadeDrive(rightXaxis * 1, leftYaxis * 1);
        m_robotDrive_second.arcadeDrive(rightXaxis * 1, leftYaxis * 1);
here is the ArcadeDriveCmd
package frc.robot.commands;
import java.util.function.Supplier;
import frc.robot.subsystems.DriveSubsystem;
public class ArcadeDriveCmd extends Command {
    private final DriveSubsystem driveSubsystem;
    private final double xAxis, yAxis;
    public ArcadeDriveCmd(DriveSubsystem driveSubsystem, double xAxis, double yAxis){
        this.driveSubsystem = driveSubsystem;
        this.xAxis = xAxis;
        this.yAxis = yAxis;
        addRequirements(driveSubsystem);
    @Override
    public void initialize() {
    @Override
    public void execute() {
        driveSubsystem.setMotors(xAxis,yAxis);
    @Override
    public void end(boolean interrupted) {
        System.out.println("ArcadeDriveCmd ended!");
    @Override
    public boolean isFinished() {
        return false;
and here is the RobotContainer:
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
package frc.robot;
import frc.robot.commands.ArcadeDriveCmd;
import frc.robot.commands.ArmJoystickCmd;
import frc.robot.commands.IntakeSetCmd;
import frc.robot.commands.ShooterSetCmd;
import frc.robot.subsystems.ArmSubsystem;
import frc.robot.subsystems.IntakeSubsystem;
import frc.robot.subsystems.ShooterSubsystem;
import edu.wpi.first.wpilibj2.command.button.JoystickButton;
public class RobotContainer {
  private final DriveSubsystem driveSubsystem = new DriveSubsystem();
  private final ArmSubsystem armSubsystem = new ArmSubsystem();
  private final IntakeSubsystem intakeSubsystem = new IntakeSubsystem();
  private final ShooterSubsystem ShooterSubsystem = new ShooterSubsystem();
  Joystick joystick = new Joystick(0);
  public RobotContainer() {
    intakeSubsystem.setDefaultCommand(new IntakeSetCmd(intakeSubsystem, false));
    ShooterSubsystem.setDefaultCommand(new ShooterSetCmd(ShooterSubsystem, false));
    driveSubsystem.setDefaultCommand(new ArcadeDriveCmd(driveSubsystem,joystick.getRawAxis(4), joystick.getRawAxis(1)));
    armSubsystem.setDefaultCommand(new ArmJoystickCmd(armSubsystem,joystick.getRawAxis(3) , joystick.getRawAxis(2)));
    configureBindings();
  private void configureBindings() {
    new JoystickButton(joystick, 3).whileTrue(new IntakeSetCmd(intakeSubsystem, true));
    new JoystickButton(joystick, 4).whileTrue(new ShooterSetCmd(ShooterSubsystem, true));
  public Command getAutonomousCommand() {
    return null;
You’re code is probably crashing. Any logs from driver station? Also u should create 2 differential drivetrain objects. U should create one with 2 arguments, left side motors and right side motors. Since u have multiple motors on each side, u can make the second of each follow the leader. See Using the WPILib Classes to Drive your Robot — FIRST Robotics Competition documentation
Tbh we sometimes have this issue on newly created projects, just copy the src folder onto a new project and it works most of the time.
I tried but it didn’t work either.
I cant copy driver station logs cause when i try they are turning into Chinese. Do you have more understandable links to learn more about Command Based?
