Command requirements in sim
I have been trying to use the command based framework to program my team’s yet-to-be-finished 2022 robot. Because the hardware hasn’t been finished yet, I have been trying to test my code using the built-in simulator, however I have encountered an issue. When trying to set default subsystem commands, I run into the following error(s), with the error of choice being determined seemingly randomly.
I wrote a very simple script that reproduces the same behavior I was experiencing with my primary code.
It should be noted that I am running this from a virtualenv, but I have tested and the same behavior is exhibited when run from outside a venv.
09:54:14:925 INFO    : wpilib              : WPILib version 2022.2.1.5
09:54:14:926 INFO    : wpilib              : HAL version 2022.2.1.1
09:54:14:926 INFO    : wpilib              : Running with simulated HAL.
09:54:14:927 INFO    : wpilib              : robotpy-wpimath version 2022.2.1.4
09:54:14:928 INFO    : wpilib              : pyntcore version 2022.2.1.1
09:54:14:928 INFO    : wpilib              : robotpy-commands-v2 version 2022.2.1.1
09:54:14:929 INFO    : wpilib              : robotpy-wpiutil version 2022.2.1.1
09:54:14:929 INFO    : wpilib              : robotpy-halsim-gui version 2022.2.1.0
09:54:14:930 INFO    : wpilib              : robotpy-rev version 2022.0.1
09:54:14:935 INFO    : halsim_gui          : WPILib HAL Simulation 2022.2.1.0
HAL Extensions: Attempting to load: halsim_gui
Simulator GUI Initializing.
Simulator GUI Initialized!
HAL Extensions: Successfully loaded extension
09:54:15:160 WARNING : pyfrc.physics       : Cannot enable physics support, C:\Users\[name]\Documents\GitHub\[reponame]\physics.py not found
Not loading CameraServerShared
Windows fatal exception: access violation
Thread 0x000027ac (most recent call first):
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\_pyntcore\_logutil.py", line 60 in _logging_thread
  File "C:\Users\[name]\AppData\Local\Programs\Python\Python310\lib\threading.py", line 946 in run
  File "C:\Users\[name]\AppData\Local\Programs\Python\Python310\lib\threading.py", line 1009 in _bootstrap_inner
  File "C:\Users\[name]\AppData\Local\Programs\Python\Python310\lib\threading.py", line 966 in _bootstrap
Current thread 0x000052b8 (most recent call first):
  File "C:\Users\[name]\Documents\GitHub\[reponame]\robot.py", line 11 in __init__
  File "C:\Users\[name]\Documents\GitHub\[reponame]\robot.py", line 19 in robotInit
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\wpilib\_impl\start.py", line 124 in _start
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\wpilib\_impl\start.py", line 58 in start
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\wpilib\_impl\start.py", line 34 in _start
Thread 0x00006804 (most recent call first):
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\wpilib\_impl\start.py", line 40 in run
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\pyfrc\mains\cli_sim.py", line 86 in run
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\wpilib\_impl\main.py", line 193 in run
  File "C:\Users\[name]\Documents\GitHub\[reponame]\robot.py", line 24 in <module>
09:54:20:804 INFO    : wpilib              : WPILib version 2022.2.1.5
09:54:20:805 INFO    : wpilib              : HAL version 2022.2.1.1
09:54:20:805 INFO    : wpilib              : Running with simulated HAL.
09:54:20:806 INFO    : wpilib              : robotpy-wpimath version 2022.2.1.4
09:54:20:807 INFO    : wpilib              : pyntcore version 2022.2.1.1
09:54:20:807 INFO    : wpilib              : robotpy-commands-v2 version 2022.2.1.1
09:54:20:808 INFO    : wpilib              : robotpy-wpiutil version 2022.2.1.1
09:54:20:809 INFO    : wpilib              : robotpy-halsim-gui version 2022.2.1.0
09:54:20:809 INFO    : wpilib              : robotpy-rev version 2022.0.1
09:54:20:815 INFO    : halsim_gui          : WPILib HAL Simulation 2022.2.1.0
09:54:21:033 WARNING : pyfrc.physics       : Cannot enable physics support, C:\Users\[name]\Documents\GitHub\[reponame]\physics.py not found
09:54:21:048 ERROR   : your.robot          : Unhandled exception
Traceback (most recent call last):
  File "C:\Users\[name]\.virtualenvs\[reponame]-fmEJ15Z7\lib\site-packages\wpilib\_impl\start.py", line 124, in _start
    self.robot.startCompetition()
  File "C:\Users\[name]\Documents\GitHub\[reponame]\robot.py", line 19, in robotInit
    example_subsystem_instance.setDefaultCommand(DefaultCommand())
RuntimeError: Illegal use of Command: Default commands must require their subsystem!
Locals at innermost frame:
{ '__class__': <class '__main__.Robot'>,
  'self': <__main__.Robot object at 0x0000019DB5F4D8F0>}
09:54:21:051 WARNING : robotpy             : The robot program quit unexpectedly. This is usually due to a code error.
The above stacktrace can help determine where the error occurred.
And the code:
import wpilib
import commands2
class ExampleSubsystem(commands2.SubsystemBase):
example_subsystem_instance = ExampleSubsystem()
class DefaultCommand(commands2.CommandBase):
    def __init__(self):
        super().addRequirements(example_subsystem_instance) # line 11
        super().__init__()
    def isFinished(self):
        return False
class Robot(commands2.TimedCommandRobot):
    def robotInit(self) -> None:
        example_subsystem_instance.setDefaultCommand(DefaultCommand()) # line 19
        return super().robotInit()
if __name__ == '__main__':
    wpilib.run(Robot) # line 24
Also, this same behavior was exhibited whether line 11 was written in any of the following ways
self.addRequirements(example_subsystem_instance)
commands2.CommandBase.addRequirements(self, example_subsystem_instance)
I tried recreating this same code in Java, and it seemed to work fine in the sim there.
Any help would be appreciated
When overriding a class using RobotPy’s bindings, if you overrride __init__ then you must call super().__init__() before calling anything else or you will end up with undefined behavior. When I move __init__ your example works fine for me.
I don’t think that we can add a check that you call it first without significantly affecting performance negatively, but I’ll contemplate it.
We discuss this a little bit in the Upgrade Notes that we started in 2020.
Filed a bug on pybind11 just to track this, thanks!
In hindsight, that makes complete sense in this context; I’m just too used to calling super().__init__ at the end with some of my pure python projects.
Thanks for the help!
