Commands Issue
Hello. I am part of team 6922 and I have various problems with the commands section of my code. I am pretty new on this, so can someone help me please?
Not without more information, no.
Here is the repository for the code. Where the commands section doesn’t build. https://github.com/AdrianC0des/2020-FRC-Code-no-pistons-
Have you read the build error?
It is impossible to tell from the repository you’ve linked (your code appears to be zipped into a .rar file), but this suggests you have not imported the dependencies correctly.
Ok. I will change that ASAP. Thanks for the help
To more easily import dependencies, you can hit tab or enter when VS Code is giving you a suggestion. That will automatically import the correct library (most of the time)
Sometimes it takes intellisense (the thing that gives you the suggestions) a long time to give some suggestions
Oh ok. Understood.
