Hi everyone, programmer from team 4377 here. We have an communication issue between the crio and the classmate. We are able to edit and save the code fine, and we can build the code as well. However, upon attempting to run the code as startup, or run it at all, communciations essentially cease. The communications light on the DS is still green, but we’ve waited nearly half an hour with no progress made in the deployment. Any help would be great
Never mind everybody, we fixed the issue. If anyone else encounters this, reset the crio and then format it. Good luck all!
I can’t be certain from your description, but this sounds somewhat like the issue that was corrected in the LabVIEW 5.1 update. If you haven’t updated, this will happen each time you try to change the code on a controller that is running a startup app and a laptop that has a dashboard connected.
Greg McKaskle
