Communications status half bar
We are having an issue where the drive station sometimes gives us a “half bar” on the communication status. Left side of the status bar turns red and the right side remains green. When this occurs, we can still drive the robot, but the drive station seems to not get messages back.
Any ideas what that means or what could cause it?
We have good battery… We have rebooted it… etc.
Thanks!
The two halfs of that bar indicate that TCP/UDP are working.
It isn’t typically a problem, because the robot communications are on the UDP one that remains green.
Often this is caused by a firewall that is blocking only some of the data.
Thank you. We did apply the bandwidth limit last night with the latest radio configuration utility. Any chance this could also be a symptom of bandwidth saturation?
