CompactRio Problem.
After many attempts of trying to send “Run as Start up” succesfully,to the CRio, we got a message that said it couldn’t connect. I turned it off and tried it again, but it never caught it. I tried to reimage it to v28, since i had it on v25 but it would always get error 60?? after the reboot process. I reset the ip adress. now it’s at 0.0.0.0 and now i can’t reimage it at all. help?
This is the problem…
Unable to complete operation because of unexpected error:
Error 1 occurred at TCP Read in NI_InternetTK_Common_VIs.lvlib:TCP Read xTP Reply.vi:14->NI_InternetTK_FTP_VIs.lvlib:FTP Get Command Reply.vi:13->NI_InternetTK_FTP_VIs.lvlib:FTP Open Session.vi->NI_InternetTK_FTP_VIs.lvlib:FTP Get Multiple Files and Buffers.vi->NI_InternetTK_FTP_VIs.lvlib:FTP Get File.vi->ConfigUtility.lvlib:OpenRemoteConfiguration.vi->ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlib: Dialog.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
