comparing encoder input against an integer
I’m trying to get code to work to test if our encoders are properly working, we are using absolute encoders and talons, we (think) we know that the wiring is correct.
#include "WPILib.h"
#include "Commands/Command.h"
#include "Commands/ExampleCommand.h"
#include "CommandBase.h"
#include "NetworkTables/NetworkTable.h"
class Robot: public IterativeRobot
public:
	Victor *V1, *V2, *V3, *V4, *V5, *V6, *V7, *V8;
	Joystick *leftJoy, *rightJoy, *controller;
	NetworkTable *table;
	DoubleSolenoid *MPS1, *MPS2, *MPS3, *MPS4;
	Compressor *compressor;
	CANTalon *T1, *T2, *T3;
	Timer *timer;
	DigitalInput *enc;
	//Encoder *encoder;
	//Encoder *sampleEncoder = new Encoder(0, 1, false, Encoder::EncodingType::k4X);
	Robot()
		//drive train motors
		//left back wheel
		V1 = new Victor(0);				//red
		V2 = new Victor(1);			//green
		//left front wheel
		V3 = new Victor(2);		//blue
		V4 = new Victor(3);				//yellow
		//right rear wheel
		V5 = new Victor(4);				//black
		V6 = new Victor(5);		//white
		//right front wheel
		V7 = new Victor(6);		//blue-red
		V8 = new Victor(7);				//black-red
		//driver and operator controls
		leftJoy = new Joystick(2);
		rightJoy = new Joystick(1);
		controller = new Joystick(0);
		//Talons
		T1 = new CANTalon(0);
		T2 = new CANTalon(1);
		T3 = new CANTalon(2);
		//compressor
		compressor = new Compressor(0);
		//pneumatics
		MPS1 = new DoubleSolenoid(0, 1);
		MPS2 = new DoubleSolenoid(2, 3);
		MPS3 = new DoubleSolenoid(4, 5);
		MPS4 = new DoubleSolenoid(6, 7);
		//network tables
		table = NetworkTable::GetTable("SmartDashboard");
		//timers
		timer = new Timer();
		enc = new DigitalInput(0);
		//encoder
		sampleEncoder->SetMaxPeriod(.1);
		sampleEncoder->SetMinRate(10);
		sampleEncoder->SetDistancePerPulse(5);
		sampleEncoder->SetReverseDirection(true);
		sampleEncoder->SetSamplesToAverage(7);
	void RobotInit() override
		CameraServer::GetInstance()->SetQuality(50);
		//the camera name (ex "cam0") can be found through the roborio web interface
		CameraServer::GetInstance()->StartAutomaticCapture("cam0");
		SmartDashboard::init();
		compressor->SetClosedLoopControl(true);
	void OperatorControl()
			while (IsOperatorControl() && IsEnabled())
				/** robot code here! **/
				Wait(0.005);				// wait for a motor update time
	void AutonomousInit()
		//sampleEncoder->Reset();
		T1->Set(-1);
		T2->Set(-1);
		Wait(3);
		T1->Set(0);
		T2->Set(0);
		V1->Set(1);
		V2->Set(1);
		V3->Set(1);
		Wait(4);
		V1->Set(0);
		V2->Set(0);
		V3->Set(0);
		MPS1->Set(DoubleSolenoid::kForward);
		MPS2->Set(DoubleSolenoid::kForward);
		MPS3->Set(DoubleSolenoid::kForward);
		MPS4->Set(DoubleSolenoid::kForward);
		Wait(3);
		MPS1->Set(DoubleSolenoid::kReverse);
		MPS2->Set(DoubleSolenoid::kReverse);
		MPS3->Set(DoubleSolenoid::kOff);
		MPS4->Set(DoubleSolenoid::kOff);
	void TeleopInit() { }
	void TeleopPeriodic()
		//DRIVER CONTROLS
		if (leftJoy->GetRawButton(5) || rightJoy->GetRawButton(10)) //Buttons 6 and 11 on joysticks
			TankDrive(-leftJoy->GetRawAxis(1) * 0.5, -rightJoy->GetRawAxis(1) * 0.5);
		TankDrive(-leftJoy->GetRawAxis(1), -rightJoy->GetRawAxis(1));
		if (controller->GetRawAxis(1) > 0.25) //Left Thumbstick on controller
		else if (controller->GetRawAxis(1) < -0.25)
			MPS4->Set(DoubleSolenoid::kReverse);
		else
		if (controller->GetRawAxis(5) > 0.25)
		else if(controller->GetRawAxis(5) < -0.25)
			MPS3->Set(DoubleSolenoid::kReverse);
		else
		if (controller->GetRawButton(1)) //A Button on controller
		else
		if(controller->GetRawButton(4))
		else
		if(controller->GetRawButton(5))
			V1->Set(1);
			V2->Set(1);
			V3->Set(1);
			Wait(2);
			T1->Set(1);
			T2->Set(1);
			V4->Set(1);
			V5->Set(1);
			Wait(.5);
			V1->Set(0);
			V2->Set(0);
			V3->Set(0);
			Wait(2.5);
			T1->Set(0);
			T2->Set(0);
			V4->Set(-1);
			V5->Set(-1);
			Wait(2);
			V4->Set(0);
			V5->Set(0);
		//ENCODER TEST STUFF
		if(enc < 10)
		else if(enc > 10)
	void DisabledPeriodic()
	void TestInit()
		V1->Set(1);
		Wait(3.0);
		V1->Set(0);
		V2->Set(1);
		Wait(3.0);
		V2->Set(0);
		V3->Set(1);
		Wait(3);
		V3->Set(0);
		V4->Set(1);
		Wait(3);
		V4->Set(0);
		V5->Set(1);
		Wait(3);
		V5->Set(0);
		V6->Set(1);
		Wait(3);
		V6->Set(0);
		V7->Set(1);
		Wait(3);
		V7->Set(0);
		V8->Set(1);
		Wait(3);
		V8->Set(0);
		T1->Set(1);
		Wait(3);
		T1->Set(0);
		T2->Set(1);
		Wait(3);
		T2->Set(0);
	void TankDrive(double left, double right)
		V4->Set(left);
		V3->Set(left);
		V1->Set(left);
		V2->Set(left);
		V7->Set(-right);
		V8->Set(-right);
		V5->Set(-right);
		V6->Set(-right);
		T1->Set(left);
		T2->Set(-right);
		T3->Set(left);
		//SmartDashboard::PutNumber("Left Drivetrain", left);
		//SmartDashboard::PutNumber("Right Drivetrain", -right);
START_ROBOT_CLASS(Robot);
Update; i put enc->Get() instead of just enc in the if statements. Now it compiles but when ran the piston affected within the if statement goes crazy and randomly shoots in and out.
If you are using quadrature encoders connected to the RIO, you should follow the example code under “Getting Encoder Values”.
https://wpilib.screenstepslive.com/s/4485/m/13810/l/241875-encoders-measuring-rotation-of-a-wheel-or-other-shaft
If you are using quad encoders connected to the Talon SRX, follow the examples in the Talon SRX SOftware Reference Manual.
If you are using analog encoder (like MA3) connected to RIO you need to create an analogInput.
But regardless DigitInput is not the correct class. Also in your example enc is a pointer to an object, which has member functions which are typically called to get useful information.
