Competition Port
plez help were a rookie team,no one here can seem to figure out the function and/or process of building a competition port
The competition port is used only in in competition [edit] or simulating competition [/edit]. I’m sure there’s a section in the manual that explains the different ports of the OI.
You walk up to the player station and plug in. This provides power to your OI and gives FIRST control over when you do or don’t have control of your robot.
[edit] Mr.Bill Gold has also reminded me of the fact that “you can use the competition port to disable your robot, and put it in autonomous mode with a dongle.” This requires wiring your own dongle, etc. Do not do this unless you know what you are doing.[/edit]
Here is the Innovation First pdf on how to do it properly:
http://www.innovationfirst.com/FIRSTRobotics/pdfs/Competition_Port_Pinout_Guide.PDF
*Originally posted by Dush *
**plez help were a rookie team,no one here can seem to figure out the function and/or process of building a competition port **
As mentioned above, to build a competition port adaptor to switch from disable/autonomous/drive modes, go to:
http://innovationfirst.com/FIRSTRobotics/pdfs/Competition_Port_Pinout_Guide.PDF
The box is very easy to build. It took us about 45 minutes without hurrying, and it works as advertised.
