Compiler Error
When I try to compile my code it gives me this error. I’ve tried a few things and searched around for a few days and nothing seems to be working. Any ideas?
Errors Found.
UTIL LIB.ASM
Errors: 265
Warnings
Reported: 285
Suppressed: 0
Reported: 0
Supressed: 0
Lines Assembled: 926
Unless you’re writting assembler, I think you may be using the wrong linker. Make sure you have the C18 stuff installed and configured. We had this problem last year.
Also, make sure that if you installed mplab before c18, that you set mplab to use the one you installed under Projects > Select Language Toolsuite.
We’ve had that problem more than once in the past.
