Hi all,
Our compressor does not start using the premade compressor class.
Things we have done:
-Changed digital sidecars
-Tested the relay slot with a different spike powering a motor
-Confirmed all three lights are on on the digital sidecar without the cable to the crio plugged in
-Tried a different relay slot
-Turned on the spike with a button instead of compressor.start()
-confirmed the digital io slot worked
Things we didn’t do:
-check the error window
-change digital modules
Any ideas? And if we can’t get the compressor class to work, can I write my own control loop using the pressure switch?
Thanks,
Zaque
