We’ve tried using samples of compressor codes from other teams that said their code works correctly but when we try to run our code it runs correctly but our compressor isn’t turning on. Could i see other codes or does anyone have any suggestion?
I don’t know if this will help, but we have had several team members “correct” the wiring by moving the pressure sensor input or relay output to the PWM connectors.
The pressure sensor should be wired to the DIO pins and compressor spike relay to one of the relay outputs on the digital sidecar (and obviously the physical wiring needs to match the channel numbers in the code).
