Compressor Error
What does this error mean?
ERROR <Code> -2206 occurred at RT FIFO Read in Compressor.lvlib:GetEnableState.vi->Teleop.vi->Robot Main.viV
Are you using ‘open compressor’ or ‘get compressor refnum’? I was told by people in my team to use refnum. The refnum is Compresser. Just that. Otherwise, I am not sure what it is.
refnum. it is opened in Begin.vi
It would be helpful if you posted your begin.vi and telop.vi.
so, apparently the spike relay had blown a fuse, thanks anyway you guys
See <R60-I> so that this doesn’t happen again, since the compressor has a large start-up current.
However, it seems unlikely that a blown fuse in the spike would cause the error that you posted.
I have also seen this error. What else would cause the RT FIFO error besides the blown fuse?
Thanks.
Post the code and the error message.
The OP error message hinted that they had the Compressor code in the wrong location (Teleop.vi).
The Compressor code all goes in Begin.vi with a Close in Finish.vi.
