our compressor will not turn on.
PCM is good. replaced it with a new one just to be safe.
PCM is slow blinking green. pressure sensor is good.
we have no voltage out of the PCM to the compressor.
can someone help?
If you are using a pcm have you made sure to change the jumper to the correct voltage? There is a little jumper inside. On top of that is your pcm wired via can bus?
it was our code. surprise surprise
