we have hooked up our compressor and are only getting 65 psi out if the compressor straight where it says in the pneumatics handbook that the compressor puts out 120 psi…anybody else having this issue?
How do you have the compressor hooked up to the cylinders, regulator, accumulators, pressure guage.
Also, check your PMs.
u might need to change what the regulators are set at.
