Compressor
I would like to know how I can burp the compressor.
pat it on the back-
ha
really I dont recall if ther is a way to do it unless you set up a solenoid (single) the vents the “a” port with nothing on that port
dahl
wait a sec.
by burp, do you mean shut off when the pressure is too high? cause to do that there’s a few different ways, but it depends on your robot setup.
*Originally posted by Ian W. *
**by burp, do you mean shut off when the pressure is too high? **
I’m guessing he means how does he depressurize the pneumatic system before storing or before working on the plumbing. (Although in that case the question shouldn’t be in the Programming forum ;))
We installed a valve in our system for just this purpose. I’m pretty sure it came in the kit last year, and I would guess it must have been there this year too.
if that’s the case, i’m 99% sure you need that valve on there, to depressurize after a round. it’s a hell of a lot safer than just pulling a tube out, plus it lessens the chance of a leak. anyone who doesn’t use that is crazy.
