Configuring Old Radio as Switch/Hub
Is it possible to configure old Radio (The one in KoP of 2014) as a switch or hub to be able to use more ports on robot. I want to use axis camera and raspberry pi, but there are not enough ports available.
For the old Dlinks, you will have to:
  1. Disable the wifi
  2. Disable the DHCP server
At that point, it should work fine as a hub/switch.
Link to the manual in case you need to learn how to reset the router and configure it:
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_v1_EN_UK.pdf
