This was posted on FIRST Q&A. Does there seem to conflict with Rules R05 and R06?
Re: Robot lifting outside of homezone
Is it acceptable to lift up disabled or malfunctioning alliance partners and transport them to the homezone in order to score bonus points?
There is nothing in the rules that would prohibit this action.
<R05> "Wedge” ROBOTS are not allowed. ROBOTS must be designed so that interaction with
opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor
defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the
ground (the top of the BUMPER ZONE) that are used to push against or interact with an
opposing ROBOT must be within 10 degrees of vertical. Devices deployed outside the
ROBOT footprint should be designed to avoid wedging. If a mechanism or an appendage
(e.g. a harvester for retrieving GAME PIECES) becomes a wedge that interferes with other
ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the
infraction.
<R06> Ramps, platforms as other mechanisms specifically designed to elevate ROBOTS during
the END GAME are exempt from Rule <R05> when they are deployed in the HOME ZONE.
Such devices deployed outside the HOME ZONE are not covered by this exemption.
Alan,
R06 is pretty specific and in keeping with last year’s interpretation. Any part of the robot within the bumper zone must remain within 10 degrees of vertical until the END GAME and "when they are deployed in the HOME ZONE. "
This needs to be a Q&A. Wayne volunteers! Actually, I’ll try to find the time to post this today.
“Devices deployed outside the
infraction.”
These bolded words are not absolutes. I believe the intent of the rule is to permit ramps to be deployed for PARTNERS to use outside of the home zone only. If while deployed, the ramp is actively used to herd tubes or play defense against the opposing alliance, that is not permitted.
An arm is a “device deployed outside the robot footprint”. R05 specifically refers to mechanisms (i.e. ramps) AND appendages (i.e. arms). Who’s to say lowering an arm to pick up a ringer off the floor doesn’t present a wedge-type angled hazard for other robots to drive up on? If the GDC rules in the Q&A that ramps can’t be lowered to the floor outside of the home zone because of R05, then unless the rule is rewritten, manipulator arms should not be permitted to do so for the same reason.
Also, since R06 says that all statements in R05 are null and void while within the home zone, does that imply that it’s legal to use your ramps to fend off any opposing robots hanging around in your home zone? This would be analogous to the relaxation of pinning and tipping penalties while on the ramps in the Aim High game.
I propose we hold off on further discussion and wait for an official Q&A answer. Then someone will post the answer in this thread.
<R06> provides a HOME ZONE exception to <R05>. But <R05> explicitly applies only to interaction with opposing robots:
…ROBOTS must be designed so that interaction with opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the ground (the top of the BUMPER ZONE) that are used to push against or interact with an opposing ROBOT must be within 10 degrees of vertical…
If you have a wedge-like part but never touch an opposing robot with it, it doesn’t violate the rule as I read it.
If there is an area on any side of the robot that would likley cause an opposing robot to climb up or under the your robot, then it will not pass my inspection.
There isn’t any conflict for 2 reasons. Alan did a good job on the first one. The second is that you don’t have to use a wedge to lift a robot, there are other ways. In fact, if they are completely disabled, a wedge would likely do you no good.
Then you must have a way of protecting that area (an angle +/- 10 degrees of vertical) while outside of the home area. Since the inspectors will not be able to know or verify how the robot will be used during the competition, all robots must be able to meet the wedge requirements while outside of the home zone.
Sanddrag,
The boldface is from the rule book, just highlighted for this discussion. In the end game when in the home zone, the rule doesn’t apply. Although I am a little fuzzy on when the ‘end game’ actually starts.
End game is the last 15 seconds of a match. There is a sound to go along with it as descibed in <G03>:
<G03> END GAME - The final 15 seconds of the TELEOPERATED PERIOD is called the END
GAME. During this period, no ROBOT may be in an opposing ALLIANCE HOME ZONE.
The intent of this period is to permit ALLIANCES to attempt to score bonus points without
undue interference. An audio signal will sound five seconds before the start of the END
GAME period, and again at the start of the END GAME period.
Remember, inspectors are not the only line of defense here. Both R05 and R06 contain wording that indicates that both the design AND use of these mechanisms is considered when evaluating compliance with the rule. You are 100% correct that you do not know how the robot will be used, so why should you make a judgment on it (as long as it’s not a safety issue)? Leave it to the referees, that’s why they’re there! Some rules are game-time rules and are not the inspector’s place to judge.
Eric,
I was just being a little facetious while thinking about the possibilities of what takes place on the field outside the home zones.
Dave, I agree.
Steve, Inspectors were just the first line of defense but you are right. We were asked to check on designs that exceeded the 10 degree rule in the bumper zone.
ok so I saw the answer on the Q&A but I would like to know if you can lift you disabled alliance partner as long as you don’t break the wedge rule. Can you lift you enabled partner and give him a lift back to homezone?? This would make our design a heck of a lot easier lol
