During 2018’s First Robotics Championship Detroit, the winning alliance of Daly field was comprised of 2767, 27, 4027, and 2708. An obvious pattern is evident here: 27. Now while yes every one of the alliance’s four teams has the consecutive digits"2" & “7” there is more. Another case of 27 is seen between 2767 & 4027 each considered one of the primary three robots in their alliance. You see, the digits that are not"27" have a difference of 27 ie 67 - 40 = 27
Here are some more examples of the 27 conspiracy, I’d be happy to see more people contribute similar findings:
- team 27 finished with 26 ranking points and had a very very near 27th that earns itself a place in this conspiracy as in match 108 on Daly (108=27x4!!!) 6th overall 2877 failed to activate during the match which 27 still managed to compensate for by doubling themselves over
(27x2) = 54
This doubling product can be summed up by boiling Q108 down to a two red robot effort by 27 & 245 with a match score 451-249.
(27x2) = (1+0+8) + (2+7)+(2+4+5)] + {(4+5+1)+(2+4+9)} ie 54=9+(9+11)+(10+15)=9+20+25 - 2877’s Q108 sabotage (or Sab-Bot-Age, aka the 11th seeded robot on Carson with a cumulative ranking point total of 27 <also 1+6+4+0=11 oh my lordie!>) Was not isolated in this match alone, as an obvious adversary of the 27 club. It’s number alone explains this rivalry, as it’s set of consecutive 7’s separated from a preceding 2 are teased by the single digit augmented 8 as it’s second digit. Also it’s digit sum fall short of 27 by 3, making it the last ordered multiple of three to not be 27. 2+8+7+7=24 3x8=24 3x9=27 9-8=1
- 4362’s rivalry with 27: another opponent of 27, 4362’s number bears much despise of the number 27:
/It’s hundred’s indicator plus it’s remaining digit sum is the last ordered multiple of three to not be 54(27x2) //43+6+2=((27x2)/3-1)x3=(17x3)
/Also it’s cumulative digit pair product’s sum is the last ordered multiple of three to not be 27 // (4x3)+(6x2)=((27/3)-1)x3=(8x3)
/It’s inside-outside digit pair product’s sum is just one less than 27 // (4x2)+(6x3)=27-1=26
/Etc these are kinda stupid and all I get it
<4362’s misfortunes result from it’s opposition of the 27 gang.
/In Q9 it alligned itself with the 29ers, 2729 & 329 (a rebellious 27 member and a founding member of the 29ers respectively) to score 329(329) and lose against 188, 2706, & 747 (7.2+2.7) whose allegiance to 27 ensured victory regardless of how much they scored(428pts), overall (/27)one upping(+27)those 29ers making them compete backwards(92)//(188+2706+747-428)/27=119//(119-27)=92
/later in match 17 overcome an opposing score of 275
/Q31 takes down 4327
/Q45 shows backwardness (45 is 54 backwards=27x2) and takes down 27 paired with/ 22nd 836 and 67th 1739 // (67-22)=45 / who were screwed against 4855, 5030, & 4362 // (4+8+5+5)+(5+0+3+0)+(4+3+6+2)=45
/Q54 despite multiplicity of 27 shows inverted distrust again as well as allegiance to 29ers again in Q54 as 4308, 2013, & 4362 combined for 454 points// (5+4)+(4+3+0+8)+(2+0+1+3)+(4+3+6+2)=45 // 45+(4+5+4)=(29x2)
/Q60 twice forcing upon 4027 the 29ers filth, as Q30 saw 4027, 1305, & 7048 combine for 346 points and lose // (6+0)+(4+0+2+7)+(1+3+0+5)+(7+0+4+8)+(3+4+6)=(29x2) / a fate of 29 given 3 times in a backwards and twist differential// (404-326)=78 87/3=29
/ I’m done analyzing the rest of these matches but there is some pretty low hanging fruit in their later matches
/ eliminations - 27 always wins - 5th, 26th, &36th ranked robots crushed 4362’s alliance in quarterfinal 2 matches 1&2 // 5+(2+6)+(3+6)+2+1+2=27 - I really don’t have all the time in the world so how bout if you think similarly or a bit differently find some other 27 conspiracies especially within Daly. Remember this all started with 4027,27,2708,&2767, and how 67-40=27 and look where it went
