Our team is using the Smart Robot Servo from REV robotics. We have used the REV SRS Programmer to switch our servo into continuous mode. Yet I cannot find any commands to run the motor as a continuous motor. All i can find are .set and .setAngle which only work in the angular mode. So which command controls the servo in continuous mode and where can i download it if needed?
There is no difference in the PWM signals sent to a continuous vs standard servo. Technically, using set()
the 0.0
to 1.0
range maps directly to a -1.0
to 1.0
range. So the servo’s set(0.0)
would be identical to setSpeed(-1.0)
on other motor controllers, set(0.5)
would be the same as setSpeed(0.0)
, and set(0.25)
would be the same as setSpeed(-0.5)
HOWEVER, while the Servo
class doesn’t have a direct setSpeed()
or equivalent method, Servo
extends the PWM
class which does have a setSpeed()
method which means you should be able to use it just fine from the Servo
class. PWM (WPILib API 2021.2.2)
