Hello FRC!
I’m working on a personal project where I’d control a Kraken X60 motor using a raspberry pi. My hope is to have an external application talk to a server on the pi which then will communicate through CAN to the motor controller. However, from what I’ve read elsewhere this isn’t so easy.
What would be the best way to do this? I’ve been looking into USB to CAN adapters, and I just haven’t had enough time with these systems to understand what I’m looking at, so I’m deferring to people who know more than I.
I believe this article from CTRE should have most of the information you are looking for. You will also want to read this article on requirements to make sure you are using a supported setup, if you have not yet read these documents. Good luck with your project!
Edit: disclaimer I have never used phoenix outside of FRC
Depending on what prices you find you could either use a canivore or other Linux socket-can compatible usb adapter, I’ve had success with a canable for non frc robotics
Same! They are usually out of stock when I look. This works for CAN 2.0 but I don’t know about Kraken with CAN FD. The CANivore however should work for CAN FD. I have not used the CANivore outside of FRC yet so can’t speak to that myself.
If you don’t mind explaining, how do you control motors with the canable. I’ve only gotten to see the data and can’t find anything about controlling online
I’ve been reading the same thing elsewhere. This is the first programming I’ve done with these systems, so I don’t actually know the pros and cons between the two. From what I understand, CAN is useful to get the feedback from the encoders and stuff, right?
Short answer is that PWM communicates one thing, one direction. CAN communicates many things, both directions. It’s up to the motor and controller what all those things will be.
In the case of a Kraken, PWM control gives you the ability to control… I believe… what percentage of battery voltage is forwarded to the windings.
With that context, this seems to be a bit of an X/Y problem.
You chose “Raspberry Pi” and “Kraken X60” - talk me through that. Why those, and not something else?
Secondly, talk us a bit through the overall goal. Regardless of the hardware chosen, what’s the outcome you’re looking for?
These are important questions to ensure you haven’t over-complicated things for yourself. There’s a lot that wpilib and the RIO provide under the hood to make motor integration easy for FRC, and picking a Pi throws a lot of that out the window. Meaning you have to re-create it, maybe.
CTRE has a lot of info about using phoenix on a pi and all the apt stuff, I’ve only used the canable for socket can with a custom brushless controller with the Linux side in python just communicating with the socket can device
Depending on what you are doing, most cases you are making use of the Phoenix motor control library and calling functions just like you do in your regular FRC code but solely in c++ (afaik).
My first use case was on a Jetson Nano driving two TalonSRX motor controllers with joystick inputs. You create a regular c++ program that includes those libraries.
I’ll see if I can find my sample code for a super basic program tonight
Edit: My old repo is gone, I might have an offline copy, but looking at the example here is not too far off from what I had for mine. I started from this and changed as needed for my project. You will see examples of setting can IDs, inverted or not, control modes, speed, reading SDL joystick (I went Bluetooth and app control eventually)
I’m starting to feel the effects of the XY problem, which is why I came here lol.
I’m choosing the Pi because the RoboRio is out of the price range and has more functionality that I need personally. My goal is to make a svelte application that will control this motor over a network (OSC or TCP, I don’t know yet). To do this, I need to set up a webserver that can control the motor.
I chose the Kraken due to its power and speed. While it will take a little bit to integrate mechanically, it is the best on the market for the purpose I’m trying to use it for.
My hope is to make a Python program that will accept inputs from the GPIO and a webserver and it will handle all the logic and then finally communicate with the motor. I’m planning on using limit switches and potentially a laser distance sensor in the GPIO, so it’s probable that I won’t need to use the CAN bus for feedback at all and only use PWM, which the Pi should be able to provide. However, I just don’t know enough about these systems to make firm decisions on how to communicate from the Pi to the Talon FX
I can’t get into many specifics, but it’ll be adjusting the height of something using a belt/pulley or a chain/sprocket system. I want to have buttons connected to the GPIO for up/down, and the svelte app to utilize preset locations that I can create, update, and go to.
Specific height. Hence the laser distance sensor. I’m guessing I could use that for position and not have to worry about the encoders on the Kraken at all
