Control panel poly-carbonate placement
Hi,
I was wondering whether there is poly-carbonate above the color on the control panel. When looking down do you look through the poly-carbonate or are you looking directly at the color?
Thanks,
Kilroy 339
Figure 3-20 on page 25 of the game manual has a good photo of the Control Panel. If you look at the wheel from the ground you’ll be looking through a sheet of polycarb. If you look at the wheel from the sky your vision will be unobstructed.
While I don’t have them on hand right now, I’m pretty sure the Field Drawings will support this.
