Hello, my team is having an issue with the 364 swerve base this year with phoenix6. Last year we used this base and it worked without any issues, but now when I config our robot the the new version it doesn’t work. The left joystick used to go forward and back, left and right, is only letting the robot go forward and back. Strafing does not work. There also seems to be something off with the rotation position too, where only some of the motors are turning the 45 degrees. We are using the same swerve modules as last year that worked so i don’t think it’s anything mechanical. Note, we haven’t figured out out encoder offsets yet, but i don’t think that would be causing this specific issue as the turn motors aren’t turning much at all when the joystick moved left or right. Our swerve modules are Mk4 L2, with falcon 500s, CANcoders and a pigeon gyro centered to the robot.
I’m sorry for any confusion, that is the file my team is using right now. For some reason it’s giving the issues stated in the original post. I only changed the configs and joysticks to be for our robot.
I used the 364 swerve base code for my team’s robot. I have it converted to phoenix 6 and configured properly, and we drove it already. Feel free to take a look here. I also implemented pathplanner to it.
