I was wondering if anyone made a conveyor belt for their robot in Inventor 2009. If so, could you please explain how you would do so.
Thank you:)
Thank you:)
If you know the shape of it, draw the sides using splines and extrude from there.
Actually we finished protyping our conveyour belt yesterday…ill get a pic tomorrow (todays meeting had to be canceled)…but basically its a frame (made it out of plywood) with the bottom of it as a guide and the top is a conveyor made of chef liner…we made the liner with about 8.5 in from the guide to compress the ball a bit…i know this probably made no sense but ill get u a pic tomorrow…i have a link to another teams conveyor ours is a little similar
We are using round belting on our robot and we modeled it using sweeps.
A similar way is to draw the path just along the inside or the outside surface of the belt (not both), extrude as a surface, then use the Thicken tool to give it a consistent thickness.
Depending on your requirements, one of the generators in Inventor might do the trick.
