Could Not instantiate Robot
  • ********** Robot program starting **********
  • NT: server: client CONNECTED: 10.24.68.102 port 57972
  • Unhandled exception instantiating robot frc.robot2019.subsystems.CargoShooter java.lang.NullPointerException
  • Error at frc.robot2019.subsystems.CargoShooter.<init>(CargoShooter.java:60): Unhandled exception instantiating robot frc.robot2019.subsystems.CargoShooter java.lang.NullPointerException
  • at frc.robot2019.subsystems.CargoShooter.<init>(CargoShooter.java:60)
  • Robots should not quit, but yours did!
  • at frc.robot2019.subsystems.CargoShooter.getInstance(CargoShooter.java:32)
  • at frc.robot2019.Robot.<init>(Robot.java:43)
  • at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:221)
  • at frc.robot2019.Main.main(Main.java:27)
  • Warning at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:234): Robots should not quit, but yours did!
  • Could not instantiate robot frc.robot2019.subsystems.CargoShooter!
  • Error at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:235): Could not instantiate robot frc.robot2019.subsystems.CargoShooter!
  • [phoenix] Shutdown cleanly
What would the issue be with subsystems not instancing usually? I’ve gone through other threads, and this hasn’t been like the others. This is a subsystem issue, so how are these usually solved?
What’s on CargoShooter.java line 60? does it happen to have an object which is referenced before being instantiated with new ?
Here’s some good stackoverflow posts that explain Null Pointer Exceptions and debugging them with the provided Stack Trace
Yes, that was it. Thank you very much!
