Here’s a preview of the data CowScout will collect this season!
Looks like it covers just about everything. Just a couple of quick questions; when will CowScout be live, and can you set up a “Test Event”. Also I would suggest making a printable version of the sheet for those teams that wish to paper scout and then use CowScout as their database.
Thanks for all the work you guys have put into this so far. I am hoping to have the team use it this year at NYC and CT.
We’re just finishing up some of the last details. Should be up sometime today along with a printable version of the sheet.
Awesome, thanks for the update Jon
Once you’ve set up an acount, is there a way to see the scouting sheet? Or even print a copy out?
Is there a way to delete a selection list? Everything else looks great!
Looks clear and intuitive.
My piece of constructive criticism: The spacing on those buttons seems a bit obnoxious (mostly because many of us will be filling these out with laptops using touch pads), maybe the final sheet can squish them up closer to each other?
I will be using the system regardless of that minor detail
Under Autonomous Mode, you have “Tipped Co-op Bridge”, but after seeing 179’s Autonomous, its possible to tip your own alliance bridge as well. Also, should there be anything about whether a team uses the bump, ramp, or both to traverse the field during teleop?
