CPU issues
Our current CPU has some weird issues to it. Sometimes, when we start it, the programming light flashes red. However, when we restart it, it will turn green like normal and one PWM will automatically go forward. Then, if we disconnect and reconnect the 7.2volt battery, we can finally have control of the robot through the OI.
Anyone have any ideas?
Reload the Mastercode V13 and see if that helps any.
Okay, when we load in the 2007 code we get the blinking red light error (programming light) with the same systems. But when we use last years customized code, it doesn’t blink red, but it does not respond.
If your programming light flashes, it means that something bad happened while executing your code. If it happens with the default code, reload the user and the master code (as suggested earlier). If you still get the red, flashing programming light, there is most likely a problem with your RC. Contact IFI.
