how many other teams r goinlg with a crab type orientation vs. a 4 wheel steer?
We’re doing a 4 wheel Crab.
when did San Luis Obispo, CA get a frc team?
Crab here as well. I’ve posted many tidbits about what we’re doing on it in several of the other threads out there. I’m sure the search function can lead you to them.
8 years ago.
that sounds good to do a crab drive
I am doing a 8 wheel crab. =)
how are you doing that does it work fine did you work out the variables
Hm. Two wheels per module, with a set of miter gears between them?
Nope, I am just using lots of skills. =)
we, were going to, but ran out of time:rolleyes:
whats crab drive
its were the 28" are the sides and the 38" are the front and back
How is the crab working for you guys anyway? we decided to use 4 wheel drive instead of it, what made you decide to use crab drive?
negative on that, thats simply referred to as “wide drive” style.
Crab drive is where the robot has the ability to rotate its wheel effectively steering them, while having them powered also. There are many different styles of doing this. Do a quick CD-media search for “crab drive” or “swerve drive” and you’ll see plenty of examples.
