In the control system overview of VS Code, it says to right click on a folder and select “Create new class/command” in order to create a new command or subsystem. When I go to do this, the option doesn’t appear on the dropdown.
It should be at the very bottom with the text “Create a new class/command” if it is not, for some reason the plugin is not properly loaded.
I deleted and re-created the project and that fixed the problem. I think something with the way our GitHub repo was set up may have been messing with it.
