Crescendo AprilTag Map
Is there any sort of timeline or information on when the 2024/Crescendo AprilTag map will be released? The 2023/ChargedUp version is here, and I know the season is very young, but I can’t find a 2024 one yet. Will it be released with the kickoff release of WPILib 2024, or sometime later?
Are you specifically asking about the one for the Limelight? What’s included in WPILib is a different format.
The locations are in the layout / marking diagram
I am trying to upload the .fmap file by changing the json file but the limelight tool is throwing an client side exception
I tried to play with the Map Builder for a bit and it makes an fmap file with 16h5 family april tags. No option for 36h11.
The following FMAP files works on my limelight. I manually changed the tag type to 36h11. You can copy the text into a text file and save it with a .fmap extension. The field image is old, but all the tags are in the correct spot and tracking. I tested with one of the vision sample images
fmap
“fiducials”: [
“family”: “apriltag3_36h11_classic”,
“id”: 1,
“size”: 165.1,
“transform”: [
-0.5,
-0.866025,
0,
6.808597,
0.866025,
-0.5,
0,
-3.859403,
0,
0,
1,
1.355852,
0,
0,
0,
“unique”: 1
“id”: 2,
“size”: 165.1,
“transform”: [
-0.5,
-0.866025,
0,
7.914259,
0.866025,
-0.5,
0,
-3.221609,
0,
0,
1,
1.355852,
0,
0,
0,
“unique”: 1
“id”: 3,
“size”: 165.1,
“transform”: [
-1.0,
0,
0,
8.308467,
0,
-1.0,
0,
0.877443,
0,
0,
1,
1.451102,
0,
0,
0,
“unique”: 1
“id”: 4,
“size”: 165.1,
“transform”: [
-1.0,
0,
0,
8.308467,
0,
-1.0,
0,
1.442593,
0,
0,
1,
1.451102,
0,
0,
0,
“unique”: 1
“id”: 5,
“size”: 165.1,
“transform”: [
0,
1.0,
0,
6.429883,
-1.0,
0,
0,
4.098925,
0,
0,
1,
1.355852,
0,
0,
0,
“unique”: 1
“id”: 6,
“size”: 165.1,
“transform”: [
0,
1.0,
0,
-6.429375,
-1.0,
0,
0,
4.098925,
0,
0,
1,
1.355852,
0,
0,
0,
“unique”: 1
“id”: 7,
“size”: 165.1,
“transform”: [
1.0,
-0.0,
0,
-8.308975,
0.0,
1.0,
0,
1.442593,
0,
0,
1,
1.451102,
0,
0,
0,
“unique”: 1
“id”: 8,
“size”: 165.1,
“transform”: [
1.0,
-0.0,
0,
-8.308975,
0.0,
1.0,
0,
0.877443,
0,
0,
1,
1.451102,
0,
0,
0,
“unique”: 1
“id”: 9,
“size”: 165.1,
“transform”: [
0.5,
-0.866025,
0,
-7.914767,
0.866025,
0.5,
0,
-3.221609,
0,
0,
1,
1.355852,
0,
0,
0,
“unique”: 1
“id”: 10,
“size”: 165.1,
“transform”: [
0.5,
-0.866025,
0,
-6.809359,
0.866025,
0.5,
0,
-3.859403,
0,
0,
1,
1.355852,
0,
0,
0,
“unique”: 1
“id”: 11,
“size”: 165.1,
“transform”: [
0.5,
0.8660254,
0,
3.633851,
-0.8660254,
0.5,
0,
-0.392049,
0,
0,
1,
1.3208,
0,
0,
0,
“unique”: 1
“id”: 12,
“size”: 165.1,
“transform”: [
0.5,
-0.866025,
0,
3.633851,
0.866025,
0.5,
0,
0.393065,
0,
0,
1,
1.3208,
0,
0,
0,
“unique”: 1
“id”: 13,
“size”: 165.1,
“transform”: [
-1.0,
0,
0,
2.949321,
0,
-1.0,
0,
-0.000127,
0,
0,
1,
1.3208,
0,
0,
0,
“unique”: 1
“id”: 14,
“size”: 165.1,
“transform”: [
1.0,
-0.0,
0,
-2.950083,
0.0,
1.0,
0,
-0.000127,
0,
0,
1,
1.3208,
0,
0,
0,
“unique”: 1
“id”: 15,
“size”: 165.1,
“transform”: [
-0.5,
-0.866025,
0,
-3.629533,
0.866025,
-0.5,
0,
0.393065,
0,
0,
1,
1.3208,
0,
0,
0,
“unique”: 1
“id”: 16,
“size”: 165.1,
“transform”: [
-0.5,
0.866025,
0,
-3.629533,
-0.866025,
-0.5,
0,
-0.392049,
0,
0,
1,
1.3208,
0,
0,
0,
“unique”: 1
I’m really curios which pipeline settings you used because the detection looks really well, and we were having some problems with it.
This is great, thank you!
looks like formatting or something messed up with this causing issues when re-uploading to the map builder, here is the original file which is working on the builder and limelight for me.
corrected_apriltags_coordinates.zip (703 Bytes)
A post was merged into an existing topic: Detect Apriltags
