cRio error
We were trying to image our cRio and came up with this error. What should we do
err.doc (79 KB)
err.doc (79 KB)
  1. run the Labview update program to get the v19 image
  2. check Format controller and select the v19 image
  3. put in your team number (I HIGHLY doubt you are team 254128)
  4. Check the always run deployed code at startup box under labview
Where do you find the v19 image? Thanks for your help. =)
in the Labview update http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
And your IP address setup (for your computer and/or the Classmate, the wireless router, the wireless bridge on your robot, and eventually the cRIO) should be 10.15.29.*, where * varies per the device. The 15.29 comes from your team number 1529.
Please see the Section 2 “Getting Started” manual available at http://usfirst.org/roboticsprograms/frc/content.aspx?id=10934
Once the IP address is set on your computer, you won’t be able to access the internet with it. You’ll have to chage its IP address setup back to its ‘automatic’ setting to do so. Again, see the doc.
thank you for all of your help. We did do the update the other day but it did not change anything so we will update again. once again, thank you for all of your information!:smiley:
if it doesn’t fix your problem, uninstall and reinstall the Labview update
