CRIO HELP NEEDED!
After many attempts of trying to send “Run as Start up” succesfully,to the CRio, we got a message that said it couldn’t connect. I turned it off and tried it again, but it never caught it. I tried to reimage it to v28, since i had it on v25 but it would always get error 60?? after the reboot process. I reset the ip adress. now it’s at 0.0.0.0 and now i can’t reimage it at all. help?
We had the same sort of problem at the beginning. I think we had to flip some of the cRio’s switches. I know we had to turn off safe mode, but I can’t remember exactly what else we did.
If that happens to be your problem, I could post a close up of our switches tomorrow.
we turned the safe mode switch and now were trying to format it that way and its been on the reboot phase about 15 minutes now. if you have any ideas or help it would be greatly appreciated.
Ok, I just asked our main programmer and he said “Turn off all wireless connections, wired connections, firewalls, security programs. Make sure the safe mode dip switch is off and that the ip app dip switch is on”
We also had to use our camera’s crossover ethernet cable to make it work right.
Lemme know if it works, cause I don’t have any other ideas.
Also make your subnet mask is set properly: 255.255.255.0
(also make sure the rest of the static IPs are correct as well)
can you post a picture of what the switches should look like? please and thanks
when it says that just manually reboot your robot and it should be fiine
It looks like this article will tell you what you need to do. http://www.chiefdelphi.com/forums/showthread.php?p=1022042
Note especially the use of the crossover LAN cable if you connect the cRIO (port 1) directly to your computer. The crossover cable is the orange LAN cable usually used to connect port 2 of the cRIO to the camera.
I couldn’t get the referenced NI document but this one is similar:http://www.bu.edu/bua-robotics/files/2011/01/cRIO_Manual.pdf
I’m uneasy about experimenting with our cRIO this close to ship date but I’ll experiment with this procedure for my pre-season classes next fall
so now we fixed the crio. thanks to everyone who helped us out. Problem now is that we cant seem to get it powered up.
check that the 24V power goes from the PD board to the cRIO (there are 4 possible connections on the connector, and you should use the two outside ones for the RIO. I forget which side is positive and which side is negative)
