cRIO HELP!!!
My team is not a rookie team so we have the cRIO from lat year. we decided not to use the classmate from devolpment. So we installed labview to a separate computer.we try to connect to the cRIO through the imaging tool but it can never find it. we have tried both crossover cables and straight cables but each time it can not find it. Any one elese have this problem?
Be sure to turn off firewalls and disable any other networking interfaces such as wifi.
Greg McKaskle
We’re having the same problem. If I find a solution, I’ll tell you.
Also make sure that the cRIO isn’t in safe mode. In that case, the DS won’t be able to find it.
Just a thought…make sure your computer’s IP address is set up to
10.XX.YY.ZZ
where XX and YY are a four digit team number (with a leading zero if necessary) and ZZ is any unused address on the network.
Also make sure you don’t have any other network interfaces such as wireless adapters enabled.
Be sure to check firewall status.
I had the probem you are describing and had to turn off the windows firewall.
