cRio help
When I installed labview 2013 and tried to deploy a program this shows up “Acess denied: This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explorer.” How do I fix it? Do I update the cRio? If I do then how?
You may be missing some steps from Technical Resources site.
  1. Install LabVIEW DVD from KOP
  2. Install LabVIEW Utilities Update (required for all Teams)
  3. Install LabVIEW Updates (only for Teams programming in LabVIEW) or C++ updates or Java updates
    Optional:
  4. Install 2013 Driver Station from NI
  5. Install 2013 FRC Bridge Configuration Utility (use this to set up your Wireless Bridge for use at home)
    The cRIO needs to be reimaged with v47 of the FRC image. (see page 10: Getting Started with the 2013 Robot Control System)
    v47 comes with the language specific update (#3 above).
