Crio Help
Our problem is that we are trying to connect to the CRIO and even though it says that it is connected we cannot detect it from the computer nor the drivers station. We have tried directly connecting it with ethernet bridges but that is not making a difference. Ever since we downloaded the new version of the drivers station it is not working and it was working before. The status light is off. Any advice.
P.S.: we have had this problem before but it worked itself out. This time it is not doing that.
:confused:
You updated the Driver Station firmware. Did you also update the cRIO? The light should only be off while the cRIO is either off or in the early stages of booting up, or if it’s still running the original “OTB” code.
