The cRIO imaging tool can’t find the cRIO. The driver account on the DS can tell whether or not the cRIO is there, but when I try to run the cRIO imaging tool on the developer account, it never finds the cRIO.
Are you using the crossover cable to connect from the classmate to the C-RIO?
Yes. Initially we weren’t, but then we realized our mistake. There was no apparent effect from switching to the correct cable though.
Turns out the problem was that the cRIO was in safe mode. We didn’t realize it because the switch looked like it was off. Also that the wifi connection was turned on.
