cRio IP change help
Our whole programming team is just stumped on how to change the cRio’s IP address and any help would be appericiated,
Team 869
Power Cords
All you need to do is image the cRIO device. To do this, pull up the FRC cRIO Imaging Tool which is downloaded with your software either Windriver or LabVIEW. Image the cRIO and fill in the section that says Team ID with your team number. When you apply the image, it will automatically set your cRIO’s IP address.
Good luck!!
